- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
October 2022
October 2022
System "home" gesture stops working
Hello all,
before I do system reinstall, which is pain, I wonder... Did anyone encounter situation that from time to time, the gesture "up" / home stops working? Gesture to access apps, which is a little above the home one, and back one both work perfectly on, but I am not able to go to home screen.
A little work around is to go to system settings and switch to 3buttons and back. That solves the issue sometimes for days, sometimes for minutes only.
Now I am fully switched to 3 buttons navigation 😞
1 REPLY 1
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
November 2022
November 2022
hello @mantaraycz
have you tried if it happens when you are on safemode ? if it does not, a software or app that you might installed might be causing the problems
