Anybody else had this problem? I want to take some long exposure shots on my A330. The Handbook says that I set the camero to Aperture and spin the wheel until it reaches "BULB".
It never gets to "BULB", just the lowest aperture availale lon the lens fitted.
Am I doing something wrong or is the camera faulty?
Cheers
I have cracked it, folks. By experimenting with my A330, I found that you have to use M mode and hold the Exposure Compnsation button down while turning the Control Dial- that gets you to BULB.
Cheers
I think you need to set the camera to Manual first: -
See Page 66 here: -
http://pdf.crse.com/manuals/4147786121.pdf
EDIT: I see you've cracked it - I was a bit slow!!!
