A7 iii goes to mass storage mode when connecting a power bank
SOLVED
profile.country.FI.title
gadgetmies
I recently was taking a long time lapse and noticed I was starting to run out of battery during the shooting. I thought I could remedy the situation by connecting a power bank to the USB-C connector. When I connected the power bank the camera switched to USB mass storage mode and stopped the intervalometer. First I thought it was just a fluke as I was unable to get the issue reproduced. Then I realised that this seems to happen on my A7iii always if I connect the power bank during exposing. If I connect the power bank in between the shots, the camera does not switch the mode and starts charging as expected. Does this happen also for others (see steps below) or is it just my camera?
Steps to reproduce:
1. Set a longer exposure time (i.e. couple of seconds)
2. Turn on the intervalometer
3. Start the interval shooting
4. During the exposure, connect the power bank
Expected outcome:
The camera continues taking shots using the intervalometer and starts charging the battery.
Actual outcome:
The camera goes into the USB mass storage mode and stops the intervalometer.
1 ACCEPTED SOLUTION
Accepted Solutions
danardi78
Escaled to support
8 REPLIES 8
danardeng
Contributor
You had used the usb-c port of powerbank?
At home, try to use a wall usb-a charger connected with a usb-a -> usb-c cable
gadgetmies
I actually only had a USB-A to USB-C cable with me when I used the power bank. I tried now with both USB-A to USB-C and USB-C to USB-C and the result is the same. I also tested with two different power banks, but that did not make a difference. I have not tested with a wall charger, because that would be irrelevant for my use case. Perhaps I still could try that at some point to debug the issue further.
danardeng
Contributor
Found similar issue on international forums
https://www.dpreview.com/forums/thread/4273105
For sure a cable that that have only power contacts help to solve (it was the case on the link), for this reason I had tell you to try more charger: probably the one you are using had all 4 usb contacts used, the camera see that data bus is connected, so it try to communicate.
Otherwise try to change usb mode, and look if some other can help to workaround.
gadgetmies
Will need to try a power only cable. Would be nice though if Sony could fix this as, at least to me, this seems like an obvious bug in the firmware. I'd prefer not having to worry about having the exact correct cable with me and having to stress about that when connecting a battery mid shoot.
Anyhow, thanks for the comments! Really appreciate the help!
danardeng
Contributor
I have to agree with you. But I dubit that a firmware update will come for A7iii.
Have you tryed to workaround with different selection on USB settings? https://helpguide.sony.net/ilc/1720/v1/en/contents/TP0001629775.html
danardi78
Escaled to support
gadgetmies
I did check the options for the USB mode, but as there is no option for only charging, I do not think changing the mode would solve the issue. Also, as far as I can recall, the selection is disabled when using the internal intervalometer.
danardeng
Contributor
Oh yes, sure. But we are looking for something that is out of user manual.
So please, try any settings (Auto, Mass storage, MTP) and check.
