new to the forum and slowly finding my way around, so please accept my apology if this has been asked before, but is there a way to use each of the slots with different memory settings. I shot mainly in black and white and have set up memory 1 for my desired settings, with memory 2 for my colour landscape settings. Is there a way to include the media slot into each of these so slot 1 goes to the colour landscape settings and slot 2 to the black and white (making post processing a lot easier with Capture One).
Any advice appreciated since I’ve just moved to the m4 from the m2.
Hi Peter,
Unfortunately this is not possible. You can only differentiate between RAW/JPG or picture/video. Please refer to:
https://helpguide.sony.net/ilc/1930/v1/en/contents/TP0002726390.html
But maybe you can shoot with quality set to RAW and apply the B&W effect by using the RAW converter.
Cheers
Thanks Peter, I was doubting that this was possible, I have different work flow processes for colour and b&w so was hoping I could simplify using the memory cards for the different colours.
