A9lll FTP
BlackBear1950
A9lll FTP
ftp on a9lll doesn't take same password i use on my a1 / a9ll & a9 for one of my server settings just says reset.Any ideas?
4 REPLIES 4
TheMaze
Hey, did you try changing the password? Restarting the server and the camera as well?
I'd also recommend that you reset network settings: https://helpguide.sony.net/di/ftp_2380/v1/en/contents/network_reset.html
BlackBear1950
Thanks for replying.i got in touch with Sony Pro support who said when yo put in your password and click save it does save the settings although it still shows reset,they said also that they have got in touch with sony development engineers to see if this can be changed as it is very confusing,let's hope they change it.
Marino.Manolo
BlackBear1950
Just updated firmware,all ok now.
Thanks.
