Recently bought brand new above camera for photos and video.
When videoing it jumps at 17 minutes then carries on recording then stops recording 12 min after that every time I use it, so will only record for 29 minutes. What is the problem and how do I fix it?
Many thanks
Not sure what you mean by jumps then carries on recording, but you can try power resetting it (turning it off and removing the battery for a few minutes).
