Buggy A7SIII
profile.country.ZA.title
caelas17
Buggy A7SIII
Someone please help me!!!!
Bug Report for Sony A7S III Firmware 4.0
Camera Model: Sony A7S III (ILCE-7SM3)
Serial Number: 4471075
Firmware Version: 4.00
Lenses Used:
  • Zeiss 16–35mm f/4 (Lens firmware 0.02)
  • Sony G Master 24–70mm f/2.8 II
Memory Cards Used:
  • Sony V60 SDXC II (R 270 MB/s, W 120 MB/s)
  • Lexar V60 SDXC II (R 270 MB/s, W 120 MB/s)
Issues Experienced
  1. Recording Stops Randomly
    • When recording in standard 25p XAVC S or 24p XAVC HS, recording stops unpredictably.
    • This occurs after only a few seconds or within the first minute.
    • Happens regardless of which V60 SDXC II card is used.
    • Camera is set to record to Slot 1 only, simultaneous recording disabled.
    • Auto Power OFF Temp set to High.
  2. Mode Switching Bug
    • When switching to Movie Mode using the mode dial (including custom modes C1–C3), the camera often reverts to Photo Mode instead or cycles back and forth indefinitely until I take the battery out.
    • This makes custom video setups unreliable and forces manual reconfiguration.
    • Issue occurs even after a full factory reset.
  3. Straight Movie Mode Unstable
    • Even when not using C1–C3, simply switching to Movie Mode on the dial is unstable.
    • Recording sometimes stops after switching into this mode or it switches to photo mode (sometimes the  Auto photo mode gets enables with the i and green camera icon). This happens when the dial is nowhere near auto mode!
Troubleshooting Already Attempted
  • Full factory reset performed (issues persist).
  • Multiple SDXC II V60 cards tested (Sony + Lexar, confirmed healthy and formatted in-camera).
  • Tried both lenses listed above.
  • Disabled simultaneous recording.
  • Verified that card write speed is not the bottleneck (recording mainly 25p).
Expected Behavior
  • Recording should continue reliably in 25p modes when using supported media.
  • Switching to Movie Mode or using C1–C3 custom positions should not revert to Photo Mode.
Actual Behavior
  • Recording stops at random within seconds to a minute.
  • Mode switching is unreliable and often jumps to Photo Mode.
  • Occurs regardless of lens or media used.
  • Problems have all occurred since upgrading from 2.11 (camera was incredibly stable on 2.11. Since 3.0-4.0 the camera has been unusable.
Request
Please confirm if these are known issues in Firmware 4.0, and whether Sony can provide:
  • A firmware hotfix or patch, or
  • A service procedure to roll back to stable firmware (e.g., 2.11 or 3.01) until issues are resolved.
0 REPLIES 0
