I bought alpha 330 3-4months back.. suddenly its started showing "Camera Error" not frequently but after few click.. Is it hardware problem or settings..?? Even my image is not framing well shifting toward top.. plzz help
Message was edited by: godse777
Hi there
Can I ask if you have tried removing the battery for a few minutes?
If that doesn't help have you checked your lens? Is it a Sony lens?
(Some problems have been reported on the net with minolta lenses)
Check it still fits correctly.
Worst case it could be shutter damage which would mean returning it for a repair.
