- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Has anyone had problems whereby PMB keeps adding copies of photos and videos already imported. Some it does it to and others it leaves alone
Camera is a HX1.
Any help please.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Amcamoldie
In the Media Files Import Settings window, are you checking the option to Import only media files that have not been imported?
If you check Import all media files each time you upload, you'll get duplicate files and folders, as the default behaviour is to organise images etc by creating a new folder for each day.
You can override this behaviour if you want all files in a specific folder. In the next window in PMB, make sure you have the Import to a new folder unchecked:
Hope this helps
Mick
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Amcamoldie
Hope this helps
Mick
