Is it possible to buy a separate rechargable battery pack to use with DPF-D1020
I find that the supplied AC power source is inconveniently very short
David
Hi David, welcome to the Sony Forums.
There's nothing listed on the Accessories page for that frame, unfortunately.
Have you considered using a simple power extension cord?
Mick
Mick
