Hi all
could anyone advise the maximum size and speed of SD card that the a77ii will work with please. TYIA
CHEERS
Hi mcgregorbart1
The Online Help Guide lists some details on the supported memory cards:
https://helpguide.sony.net/ilc/1410/v1/en/contents/TP0000390699.html
Cheers,
Win_88
Hi there,
Welcome to the Sony Community.
I'm looking into this and will update the thread when I have more information for you.
Best wishes,
Sean
Hi mcgregorbart1
Cheers,
Win_88
Thank you
