I have downloaded and installed the latest Raw driver for windows 7, but it will not work with windows live gallery.
Has anyone experienced the same problem
Is it just Picture Gallery that it does not work with? Have you tried opening Windows Explorer and choosing Filmstrip? Are RAW images shown there?
If so it looks like Picture Gallery cannot read the Sony RAW format.
Thank you for your reply. I can open the Sony Raw Pics in Windows explorer, but they will not open in the Picture Gallery. It would appear Picture Gallery requires an update.???????????
