VCT-VPR1
MyCloud
VCT-VPR1
Is it possible to use the VCT-VPR1 with a remote terminal camera? If so, is a cable for that sold separately?
Thank you!
1 REPLY 1
Marino.Manolo
The VCT-VPR1 is a tripod provided with Remote Commander functions for cameras.
You can use the built-in Remote Commander in the pan handle to operate cameras that are equipped with the Sony Multi Terminal. This tripod may not be compatible with all cameras with Multi Terminal. Please visit the Sony website for the compatible models.
http://support.d-imaging.sony.co.jp/www/cscs/accessories/compatibility.php?area=gb&lang=en&mdl=VCT-V...
Manolo
