when I look in veiwfinder there are lots of dust/dirt spots they are not on images how can I clean the veiwfinder....
Message was edited by: beboyle14
Hi beboyle
It's not a particularly straightforward job, pretty much the same sort of task as cleaning the sensor and about as user-friendly – the risk of damage is about the same, although the parts involved (should you damage anything) are not as expensive as they are with sensor cleaning.
The dirt you can see is usually on the inside of the camera when you remove the lens, either on the mirror or the underside of the viewfinder screen. As with sensor cleaning, you can sometimes have success with a blower brush but anything more invasive (using liquids, etc) is simply not worth the risk. Even with blower brushes you always run the risk of blowing dirt onto the sensor, turning a simple annoyance into a shot-ruining problem.
I'd recommend you don't attempt to clean this yourself unless you're particularly competent at such things. The good news is these cleaning tasks can be carried out on your behalf by any competent camera shop technician at really modest cost. If you ask at a reputable high street store they should be able to give you a fixed quote and it shouldn't be much.
Cheers
Mick
Hi beboyle
Cheers
Mick
Thanks again Mick
