OLED 55AG8 Panel Refresh
Selkieboy
I keep getting this refresh message. When I accept the refresh, TV switches off and after a while I get red flashing light, ( 6 flashes ).
This is happening after every switch off now. TV is less than 1 year old.
Can this be resolved easily or should I send TV back?
4 REPLIES 4
Selkieboy
https://www.sony.com/electronics/support/articles/00173467
The Sony site says this shouldn't be done more than once per year as this will reduce screen life.
I have accepted the refresh but not sure if it's actually doing anything.
rooobb
Have you installed the latest firmware for your TV, it should address the LED problem e so probably also the continuos requirement of panel refreshing
Selkieboy
Thanks Rooobb,
The update seems to have fixed the problem.
DavidinDerby
I've got exactly the same problem. Can you tell me more about the firmware update and how you do it? Much appreciated.
