I purchased a 32” full had tv as a Christmas present for myself as I am virtually housebound. The picture is superb! The sound is dreadful very muffled and echoes sometimes so bad I can’t watch it without headphones! I am sure there is a way to fix this but I am 71 and not very technical! Can anyone help please?
Usually you should find various options in the sound settings, that will help you to improve the sound a little.
However, since the TV speakers on a flat screen are quite small you shouldn't expect any hi-end sound quality.
Cheers
