Subwoofer compatibility
Graham100
I have a XR-55A80J tv and wondering if there are any compatible wireless subwoofers that are available?
2 REPLIES 2
royabrown2
Hero
@Graham100
From the spec of your TV:-
https://www.sony.co.uk/electronics/support/televisions-projectors-oled-tvs-android-/xr-55a80j/specif...
SUBWOOFER OUTPUT(S)
So you can’t just add a sub.
However, you can add pretty much any soundbar or other home cinema setup you like, and give yourself a sub that way.
Graham100
Thank you for the quick response. understood
