Is there any way to adjust motionflow on non native sony apps? I can only adjust it on native media player, netflix and watching tv. In any other apps it says that is unavailable.
That's not possible unfortunately.
Cheers
MOtionflow is only modifiable in Sony Native media player, Netflix and Tv watching. In any other apps it says not available and it is adjusted in the default setting.
Hi mtampou , as Peter said, the option to adjust different settings varies on installed apps and might not be available. As a workaround, try adjusting the desired setting from the Home menu settings before getting into the app.
How can i adjust the settings from the home menu? If i click home and then adjust the picture it enables automatically TV viewing. And if i click the button to adjust it , on Applications section motionflow is locked (before entering in any application). So is there anything more i can do ?
Hey, do you mean it's locked on the settings menu as well? What's the model number that you own? I will look it up for you.
it is KD-43XH8196
@mtampou does this happen on the latest software version as well?
Have you tried pressing the Option/Action Menu button while you're watching something (i.e. quick settings)?
Yes Joe.
It does this even on the latest firmware upgrade. I tried set motionflow when the application is open but it is locked on normal, and does not change to custom or any other else value.
Does this happen on specific apps or any/all of the downloaded ones you have?
