Good day!
I've been having problems with my 7 day old Sony Xperia C3.
It started when I opted to charge my C3 at 11% battery. I plugged it in the socket using the charger that was provided and it suddenly turned off.
From then on, my C3 won't charge anymore.
Aside from that, when I try to turn it on after leaving it "Charging" for ten minutes it boots the Sony screen up to the Xperia blue wave screen but it turns off with a short vibrate and a low battery sound. (the red light indicator doesn't light up continuously when plugged, it lights up for about 2-3 seconds then turns off).
I've tried using other android chargers but yielding the same results. I also tried connecting it to my pc but still the same.
Sorry to hear this but you would need to either return your device to the place of purchase or contact Xperia care and have your device inspected http://www.sonymobile.com/global-en/support/contact-us/
help pls.
my sony xpreria c3 got switch off by its own when i am trying to switch on then in that condition nothing is happening i also tried after connectiong it with charger.
this problem in past also came in mobie in that condition it took 6 hours after that it turned on
o have the same problems whats that i think the problem is in all
t:smileyworried:he devices xperia c3 my device have 7 days old
