Battery Charge
OPGELOST
profile.country.en_GB.title
zygouk
Bezoeker
Battery Charge
I have a mains charger for my PRS505 reader. However the charge only lasts for about 8 pages. Does this mean the battery is kaputt and if so is it replaceable?
1 GEACCEPTEERDE OPLOSSING
Geaccepteerde oplossingen
Blencogo
Are you  using a Sony branded charger?  Have you tried connecting it to a PC  using the USB cable and seeing it the battery charges correctly?
Battery life of the PRS-505 is predicted to be at least 4 years so if your battery is not charging it is faulty and Sony should replace it.
The battery appears to be a mobile phone type and in a few years there are going to be lots of people asking this question.  At present Sony USA are selling a Reader replacement battery for $70 which is very costly and I expect cheaper alternatives to be made available as soon as demand rises.  They are already available in the USA for $22.95
http://www.batteryship.com/htmlos/htmlos.cgi/batteryship/catalog.html?item=LIS1382-J
Google may find one closer to home.
:thinking:
Bekijk de oplossing in de community in het oorspronkelijke bericht
1 ANTWOORD 1
Blencogo
:thinking:
