BDV-4100 no sound - optical from pc
CptChronic
Hello,
I want my home cinema connected to both my pc and tv. TV is connected though ARC and is working fine. The PC is connected with an optical cable but there is no sound.
If i run the optical instead from pc to tv i get sound through the home cinema but its not 5.1.
Can this not be done with the optical cable?
Thanks
Tags (3)
2 REPLIES 2
Sean_Mc
Moderator
Hi there,
Welcome to the Sony Community.
Can you let me know the model number of your TV?
Best wishes,
Sean
rooobb
@CptChronic  ha scritto:
Hello,
Thanks
Any tv has only OUTPUT optical socket, you cannot deliver sound to it in this way. You have to connect your PC to TV via HDMI (both audio and video)
