Htx8500 wireless sub
profile.country.AU.title
mmackieh
Hello,
is it possible to add a wireless Sony subwoofer to the htx8500? I recently purchased the htx8500 and I find the integrated sub extremely weak even at high settings and it has no punch to it like adding extra base to a normal speaker.
would be great if I can pair it with an extra sub
4 REPLIES 4
Anonymous
Not applicable
Hi there,
Hopefully a community member can help.
Best wishes,
M
mmackieh
Thanks but unfortunately No one seems to have a solution here
LightFoot
Specialist
Hi @mmackieh   Unless it was advertised as having a optional wireless subwoofer then no. Sony systems are generally sold as what you see is all you get.
The_Black_Rose
Specialist
Hi Mmackieh,
I don't think it's possible to pair a different subwoofer than the supplied one.
Cheers,
The_Black_Rose
