Network connection failure of BDP S490
SOLVED
kgallacher44
My Sony BDP S490 DVD/Blu Ray player can't connect to our Sky Hu router.  It is a wired connection and the setup says "physical connection ok"  but "internet connection failed".  All the network settings were set to auto.  It was working, then stopped.
1 ACCEPTED SOLUTION
Accepted Solutions
DarranA
Moderator
HI there,
I would contact Sony Support regarding this issue. Network issues can be troublesome and they will help determine whether this is an issue with the BDP S490 or a router issue.
I hope this helps.
Cheers,
Darran
4 REPLIES 4
rooobb
Try to set manually a static IP and public DNS for your BDP  (such as 8.8.8.8 and 8.8.4.4)
kgallacher44
tried that, didn't work. thanks
DarranA
Moderator
HI there,
I hope this helps.
Cheers,
Darran
kgallacher44
checked the cable and it was fine, prob a glitch with the player. thanks
though
