What other hdmi devices have you connected to the amp?
Something like this happened to mine Str-Dh820 as well when i had my pc connected ,the hdmi passhrough didnt work ,taken the pc hdmi cable out worked fine,so check that your devices are compatible with this function
In my case my pc hdmi cable blocked the hdmi passthrough function ,so before you switch off the amp you choose the source (ps3 or sky) and then you can listen from tv the chosen source ,is that correct ?
Lets see your tv settings ,
What model yoy have ,usually sony tv's have the arc in hdmi1 ,try this
Audio>hdmi only
I see ,where video=auto, has an hdmi option ?
Good luck ,let them sort it for you
