sony strdh190.cek Amplifier
mcgee9t2
Hello,
i have recently purchased the sony strdh190.cek stereo reciever.
Unfortunately it has arrived with a European two pin plug (type C - so no earth, double insulated).
i contacted the shop which sold it to me, they were unaware that it was that type of plug and have given me an adapter, however, i don't want to use the adapter as a permanent solution, therefore i am going to remove the plug and put a standard UK three pin plug on. voltage and frequency obviously match UK as we are all now harmonized...
any reason i cannot do this, and can anybody advise of the fuse size required (3A)
Tags (1)
2 REPLIES 2
EdwinaU
Moderator
Hi there,
Welcome to the community.
We will check this and get back to you as soon as possible.
Best wishes,
Ed
The_Black_Rose
Specialist
Hi Mcgee9t2,
I don't really think it's safe to use a different plug other than the official Sony one.
When did you buy this device and where did you buy it from?
Cheers,
The_Black_Rose
