XE85 and STR-DN1070 auto selects sound field
profile.country.SE.title
RoGunner
Hi, My tv or receiver is forcing the choice of sound field. Im connected thru ARC and everything else works fine.
If the tv sound setting is on standard the sound field Multi st will be selected for me, and if i change to cinema for example HD D.C.S is selected. I can change it manualy but need to do it all over again if the input is changed.
XE85 and STR-DN1070
I want to use the sound field direct, always.
How do i get the setup to stay at Direct wich is the one i want to use regardless of input?
Any ideas? Thanks.
2 REPLIES 2
Anonymous
Not applicable
Hi there,
Is everything updated to the latest firmware?
Welcome to the community. :slight_smile:
Best wishes,
M
RoGunner
Yes everything is updated.
Recently got the tv. And updated the firmwares at the same point.
So dont know if its the "new" tv or the firmware. Supect they are in it together:P
Had the 8505 tv from 2015 but it crashed. Never had the problem then.
Seems like its the ARC that mess it up? Very anoying...
Thank you:slight_smile:
/R
