Pin is required for additional security when unlocking phone
Are you referring after restarting the phone? if so, that's normal, if something else do elaborate.
IveI just got fone yesterday my daughter got me it. IIwasI charging it and went to look at texts and as couldntc get in isothermal my thumb print it said emergency pin.. Ect I've not set a pin number andanotand very tech minded. Should I take it back to shop.
Restart the phone and try again, also, if you have enabled the fingerprint a pin/password will be required.
Where do I find the password..
I'm going to take it back into shop she got it from tomorrow. Don't really know what I'm doing with it. Thanks anyway.
I'm sorry to hear that, but if you set up the fingerprint lock, then you were asked to enter a pin lock as well.
Hi @Laymon, welcome to our forum!
On devices that features a fingerprint sensor, you will still need to use the backup screen lock that you set when adding the fingerprint and below you can find the different situations when this is needed.
If you forget your screen lock, you will need to reset the device using a computer and the Xperia Companion program, or follow the instructions below and do it using the Google service called, Find My Device. Do note that all data stored on the internal storage will be deleted.
I hope that helps!
Thanks Jonas,after many hours and a good few swear words,ive given it into a fone fixing shop who have advised me that they're going to have to get rid of google and add new one(incase you've not guessed im not very techie minded..lol) they did spend 2hrs on it today trying to fix it,without success.but thanks again.
Hi again @Laymon and you're very welcome!
It sounds like they are going to remove the Google account to add a new one in your device, and if they do that, it's very important that you have the credentials for this account, as you may need them later on.
There is an anti theft feature in all our newer devices that will trigger when the device is reset and you will then need to use the Google account that was added in the device to verify yourself as the owner.
Let me know if you have any further questions once you are up and running with the device again and have a great weekend!
