Problems with external memory
Hello or a sony l1 or bought an external memory, when I insert it tells me sd card damaged or not present. How can I make him recognize, thank you.
Problemi con la memoria esterna
Salve o un sony l1 o comprato una memoria esterna, quando la inserisco mi dice scheda sd danneggiata o non presente. Come faccio a farlo riconoscere, grazie.
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
What if you reformat the SD card?
