Blue_Connor
Settings problem
I accidentally denided access to the contacts and I can't create them.
Can you do something to help?
If you did I would be very grateful
2 REPLIES 2
profile.country.RO.title
_alexdon_
@Blue_Connor do you mean the shortcut from home screen? If yes, just tap longer on the screen, add shortcut, contacts app.
alexdon
Jonas
Master
Hi @Blue_Connor, welcome to our forum!
It sounds like you denied permissions for the storage in the device, but you can change this if you to go Settings > Apps > Contacts > Permissions. Make sure that all permissions are enabled, or else you may not be able to save/edit contacts.
I hope that helps! Slightly_smiling_Face
