I Forgot My Xperia Tipo Pin. Now What Can I Do ??
I Knw The Pin Numbers I Entered For Security,
But Now The Phone Did'nt Accept That Code.
So Plz Help Me Out.
Thank You.
The big problem is i can't connect to the Sony PC Companion as well! It says that i must try reconnect but that doesnt work either!
How do i get the flashtool???????????????:smileyconfused:
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
Make sure the device is not connected to computer or laptop and turned off (sometimes you have to press power button and volume up until the device vibrates 3 times or on some devices you have to press the small button near the SIM tray or on the back of the device).
Open PC companion->support zone->phone/tablet software update->repair my phone/tablet blue highlighted.Follow the steps given,do not connect your phone until prompted to press volume down while plugging USB cable. If PC companion does not start the repair process, you might need to run it in compatibility mode with Windows 7 (in some cases XP).
In my case, it does not show "Select Zone" option
In my case, it does not show "Support Zone" option.
Thanks
