How can I disable the internet connection since the phone switches onto internet at random when I do not what to go on line and I am getting unneccessary charges
Решено! Перейти к решению.
You can delete the account in the Settings > Connectivity > Internet Settings menu. If you delete the account there is no problem accidentally connecting
Dear Jeff,
Thanks for the answer and I have (I think) deleted the account setting. Only time will tell.
Cheers
John
