Hello everybody,
The last days I checked with Pc Companion if there was the ics update for my sony xperia neo v.
Today I get the message that I could update my phone to android 4.0. So I did.
But when I follow the steps I get a problem. I have to shut down my phone wait 5 seconds, plug the usb-cable in the computer, hold the back key and plug in the micro usb-cable in my phone. So I did. Pc Companion regognized my phone as a sony ericsson phone, but in the update progress nothing happend. After some time, my phone stopped in that modus and start up to load my battery (my battery is over 50%) I have tried it many times, hold the back key longer, but nothing helps.
Has anyone an idea?
Are the servers of sony overloaded?
Ps. Sorry for my bad English
SUS ( Sony Update Service) ... download and install it on pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
or
http://www.sonymobile.com/global-en/tools/update-service/
Both the links are same
________________________________________________________________
or
