Do you have the option to compare the signal with another Xperia neo?
It's really difficult to judge if this is a problem, or how the phone is designed, since every area is different.
If the problem is to the point of dropping calls, you may want to consider a possible defect, and you'll want to call us to check on this: www.sonyericsson.com/cws/corporate/common/contact/phonelist
