I am Using a set of sonny HeadPhones Plugged into the Headphones Jack on the Side of The TV, and this is Working Fine.
I managed to Use the Sound Settings Somehow and was able to get the TV Speakers to work as well.
But now I have just bought a Sound Bar and I can't seem to find another Audio Output for them, without unplugging the headphones and using that Socket, But I want to Use Both at once.
I Tried Every Socket on TV apart from the Headphone one and got nothing.
Even tried different settings in the Setup, no luck.
I did find one interesting Socket Marked ( VAR/FIX ) which the Manual Refers to as ( Audio Output ( Phono Jacks ) ), But there appears to be No Output from this as well.
Can anyone Offer me some Workaround for this problem.
Did you buy a brand new soundbar and want to connect it to your TV using an analogue connection?!? It should at least support the optical audio connection that is available also on your TV....
I've Solved the Problem, Baught a New TV
