i have a Sony receiver STR-DH100 and i cannot connect it to my new KDL55HX753 TV to get a better audio.Do not know how to get around the right cable to connect these equipment.does anyone have a great idea about this stuff?
I don't think you can as there are no digital inputs on the receiver, so it might be time to upgrade.
http://www.sony.co.uk/hub/home-cinema-systems/range/2 - The new Sony receivers are absolutely fantastic.
you would need to upgrade to an a/v reciever that has at least an optical connection then you can connect your tv to this using a digital optical lead for much greater sound.
Thanks for your info.which receiver might you recommend?
Hi again,
well that would depend entirely on your budget but most of the latest Sony A/V recievers are excellent.
her's an example for you.
http://www.sony.co.uk/product/hcs-home-cinema-receiver/str-dh820
