Issue with blank display on powering on 40" Hx723
profile.country.en_GB.title
SMFire
Hi All,
I've been having issues with powering on my HX723. Typically it should show the input i.e. HDMI 1/2/3 etc when powered on. However, I don't get any sort of menu displayed on screen when powered on. At this point if I power on my Tivo it immediately switches to that input and things are back to normal. If no video input is given than it just remains in the blank screen as if it is turned off. I can hear sounds when pressing menu, home and other keys, just no display.
Has anyone else faced a similar issue ?? Any inputs would be appreciated.
Edit: By power on, I mean bringing it out of standby pressing the remote power button. It is already turned on from the mains.
Message was edited by: SMFire
2 REPLIES 2
SMFire
Anyone have any thoughts on this ?
Bravia55HX
this is likely to be that the last known input for the tv was the TiVo box and when you turn the TiVo on you have display!, mine does exactly that, the tv just remembers the last known input soarce so nothing to worry about there.
