Is there a way to send the audio via bluetooth to my headphones.
My headphones link to my phone (Android), my laptop (Linux, Windows) and other devices.
When I search from the Sony TV id does not find ANY devices.
Regards
Stuart
Do Sony make mice?
I think any mouse will do, that confirms with Bluetooth v3.
"Only Bluetooth mice (up to Bluetooth v3.0) can be registered to the TV. You can register up to 2 mice."
Cheers
Hi there
The bluetooth on the TV, is ONLY to link to computer mice. It cannot be used for any other function unfortunately.
Cheers
