Using USB Flash Drive with Kdl-42ex440
DAH123
I would like to use a 128gb USB flash drive with my Kdl-42ex440 TV to display .jpg photo's.
Quick question: do all pictures need to be in the main root directory or can they be in sub folders? Ideally I would like to be able to navigate through the sub folders to view the pictures inside.
Thanks,
Dave
1 REPLY 1
Anonymous
Not applicable
Hi there
Photo's can be in sub directories.  Sometimes Sony lists the maximum amount of files and folders that the tv supports, but cannot find this info, so you should be fine anyhow.  But if you find it struggles, keep files to less than 1000 per directory.
Cheers
