Yesterday I bought a new Sony Vaio VPCEC1M1E/WI from Spain.
My problem is that the Windows 7 Home Premium it has just 2 languages:Spanish and Catalan(a spanish dialect)
I am not so good at spanish and expecialy in Windows Terms:smileyplain:
I searched the internet how to instal an English Language Pack but i found that ownly Windows 7 Ultimate has this option.
Can you help me solve the problem?
..oh...and yeah....i have a WIFI conection where I stay but because i am not so good in Spanish dialect i cant connect to the internet conetion.
so can i do any update to my Vaio without Internet?
i mean i get all the update files on my USB Stick and then install them on my Vaio?
Can i do that?
I am prety good in Windows XP but in Windows 7 i am a little bit a begginer...and because it is in spanish it is a lot harder:(
pls help me...
--AvorO--
Ty for your reply thalamus_,
I tryed your metod but i dident like it:smileyplain:
It transforms ownly the important stuff in English but not all.
Now I want to change the Windows entirely
I have already Windows7 ready to install it but before that i have some questions...
1.Where can i find all the Drivers and Programs that are installed on my vaio laptop?*
*I mean can i find them all on the internet?Is there any pack that contains all(i know the Drivers are in C:/ but where i can find the install .EXE for the rest....Vaio Gate,Vaio Care,and so on...)
2.After i change the entire windows cand i make the back-up for it?**
**I mean that can i put the entire new windows+all the drivers and programs in the Recovery Partition?
Thanks,
AvorO
Hi Avor0,
sorry you didn't find my suggestion helpful but as I said I hadn't tried Vistalizator so couldn't comment on the changes.
You can download the pre-installed drivers and utlities for your Vaio from the Vaio Support site but unfortunately Sony don't allow you to download any of the pre-installed applications..:smileysad:
The easiest way to to back up your Vaio once you have installed Windows 7 and have everything set up to your liking is to use something like Acronis True Image and use this to create and store a backup image, use the following link for more information on: Acronis True Image
Depending on what you have created a backup of you could restore your Vaio, user settings, all your personal data, etc in the event of a fatal system crash or virus attack to as it was when you created the image..:smileywink:
