I have using my Sony Vaio VGN-FS285M for 2 months.I tought it has double lamb on LCD screen. But in some web sites in 315 M series writes double lamp in 285 series only writes xblack lcd
Has my notebook double lamb on lcd or not?
Thanks for answers...
so it has a single lamp
is there a big difference on screen between single and double lamp models
I wanna know if it has double lamp or not??
Most LCD screens use a single lamp to illuminate the screen. XBRITE displays feature dual lamp illumination for evenly destributed light across the screen. This means that the lighting across your screen will be better with two lamps. I haven't seen a dual lamp lcd screen, but my vaio with single lamp works fine for me.
If you have to work whole day on your notebook, it might be wise to consider dual lamp, as ergonomics are even more important then.
My cousin bought a notebook same series as me...Fs 315s..İt has double lamb in 2-3 weeks I will see his notebook...
Then I can decide how good is double lamp technology in lcd screen...
Perhaps you can take some good pictures from both standing next to eachother. This way we can see the difference too.
A picture like that would go great on my papers.
