Hi all i am about to buy this card tomorow but need a bit info first
new card
from what i have managed to find out it is better than what i have in my pc standard
any info would be great ie will it fit will it be alot better ect ect
seams to be a good price thou :smileygrin:
anyone know what power supply i have
yup its for my PCV-RX402 james
there must be a few bigger cards out there that i could buy
pc world has a few realy good prices on cards just now
You're probably best asking at www.vaiovillage.com or looking on the label.
I guess it's a 350W
i think i will have another look inside and do another clean out
dont know wether to just trust pc world with a sugested graphics card or not after all its my pc not theres they will just want the sale
bit worried about the power thing now
thanks again you all
james what pc whas it you had the probs with and did you find a card that was ok ?
thanks
all again
loads of info now
Doesn't PC World have 50% off upgrades so they fit the card there and test it?
hey james i bet it was great at the time :smileygrin:
might end up with a new tower if it gets hard to do anything with it just a thought how hard would it be to put my gubbings inside a diffrent tower with a new power supply ect or is it just not worth it
do sony not do upgrade power packs ????????
or are they just over priced
i would love to just get the graphics up a bit hey it runs not bad games as is like unreal 2004 just not cranked right up on the graphics side
would love to keep it as is with a bit better a card in nothing huge just better
Their work is garunteed I guess, you would have to ask.
I've never experienced their work
