Hi, I have a Vaio VGN-NR38S, I tried to delete all my personal info before giving it to my daughter, sorry guys but the MOST important bit didn't paste here, I stupidly DELETED THE OS Vista Home premium also. could anyone help please. TY, Pete
Sorry to waste you valuable info without giving you the FULL FACTS!
Message was edited by: pedroalki
Hi Pete,
The simplest method is to return the notebook to factory settings.
You can do this either with the recovery disks you should have created or by using the hidden recovery partition if it has not been deleted. To access the recovery partition tap F10 at boot.
The trouble shooting guide will provide more details of the procedure.
ftp://ftp.vaio-link.com/pub/manuals/RecoTS/2008Q2_TRG_EN.pdf
Rich
Hi Pete,
Rich
Hi Rich, thank you very much for taking the trouble to reply, I appreciate it very much.
I will try your suggestions tomorrow.
Best wishes,
Pete
