...good afternoon from sunny UK, I've just upgraded the VGN-FZ11M from WIn vista to win 7 32 bit os, unfortunately before considering upgrading the RAM to 2* 2Gb's...How do I get around this- easily...!?#
Hi wilco602003 and welcome.
According to Sony's Specifications for your model, the maximum RAM installable is 2GB (2 X 1GB)
http://www.sony.co.uk/support/en/product/VGN-FZ11M/specifications
If Vista ran OK with 2GB, Windows 7 should be OK.
...thanks for the info Blencogo, i was aware of this limitation using a Vista OS but since upgrading the OS to Win 7 (32 bit) I downloaded the Crucial Memory Advisor tool...viz.
We guarantee that the upgrades you find through the Crucial Memory Advisor tool will be compatible with your system, or your money back.
...and was reading the yadayadayada at
http://www.crucial.com/uk/support/improve_computer_performance.aspx
...when it struck me that perhaps utilising a 64 bit Bus would speed up throughput a tad...Now what you appear to be suggesting is that:-
...I appreciate that what Crucial are suggesting is quite possibly based on commercial need rather than the Customer's, especially after going thru' the pre-installation checklist...Good Lord, simply defragging my HD would make one hell of a difference especially using large spreadsheets...
...waddya say Blencogo, must admit I'm tending to lean in yr direction on reconsidering the issue...
...regards...
...wilco602003
