Hi i need some advice about my notebook its a vgn-n31s/w .
The problem is i started getting really bad popups since december and i brought it in august i tryed disableing add ons what i got told by a expert and they also said try spybot this has unsucessable i was just wondering what else i can try as its driving my up the wall.
The popups either take the page away what i was on or appear on my bar.
Thanx claire
sorry about spelling errors!
Hi Claire
Try SpyDoctor. This can be downloaded free from to Google packs. By selected more on the Google home page.
I use, AVG, spybot, adaware and spydoctor. Which all mostly are free.
Hope this helps, is it spyware you have got on your computer?
if this dosnt work, not much will, unless its a virus. If its a virus you can call Microsoft and press 9 on phone keypad.
Otherwise you need to do a fresh install of the operating system.
Ok thanx just a bit angry knowing i have only had this computer 9 mths
Hi
No problem. Its not the computer. It is the software on the computer.
I would recommend a full system reinstall. This will sort out the problem. Make sure you do a back up of your emails etc....
