hi All,
hopefully not too much of a daft question, does anyone know if i can get a car charger for the M series netbook, ie, VPCM13M1E, or if i left it on stand by with the lid down, would the battery last 8 hour+
thanks
Hi holidaychicken,
In-car chargers are available from a number of suppliers but these are not genuine Sony parts. You could try the following link but it will be necessary to give them a call as your model is not listed.
http://www.laptopshop.co.uk/laptop-car-adapters.htm
Alternatively an DC/AC power inverter, which are now fairly compact, used in conjunction with your standard power adaptor will do the same job at approx. the same cost.
Hi holidaychicken,
hi Rich, thanks very much for the replies, i didnt even know you could get DC/AC convertors which i think would be the better solution.and cheap too
thanks again
You're very welcome holidaychicken
WORST SERVICE EVER!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Hi annaabcdefg,
welcome to the Sony User Community Forum..:smileyhappy:
This is an old thread but can you give us more info on what you are having a problem with and maybe someone from the community will be able to assist you..:smileyconfused:
If you would prefer to speak directly to officail Sony support then you can locate the contact details by clicking on the following link - Contact Sony support
