Please, can anyonw recommend a TV tuner for a Vaio laptop? I have found some stuff on the web (after goggling for it) but I don't see a clear choice. First, I do not see if there is any PCMI card sound enough, and second, has anyone tested a USB TV (analogic) tuner?
Thanks.
Xavier.
hauppauge , yep I've used one also , found it very cool,
Make sure you get a USB2 one, don't want to loose frames...
Hi Xavier
In case you're living in Germany whatch out for DVB-T areas
(Berlin, Frankfurt)
The analog tuners will not do anymore in the future.
Tuners capable for DVB-T are rare and expensive in the moment. Example:
http://www.borschel-electronic.de/os/product_info.php?manufacturers_id=&products_id=639
Günter
They're planning similar here.
