Sony Vaio Duo13 (SVD1321M2EW) poor wifi
deejohnny
Hi i'm Currently having issues with the wifi in my vaio duo 13 (SVD1321M2EW) the wifi recepion is so poor i can hardly get 3 bars and lucky to get 20Mbsdownload speed, my surface rt in the same room picks up full bars and nearly 150Mbs!!!!! also the connection randomly drops to nothing leaving me with no connection!.I know this is a new machine but this is very poor for a machine that costs nearly £1.5k and getting out gunned by a rt device, even the built in vodaphone modem can pick up full bars from a mast god knows were but the vaio cant even connect to a router in the room below.anyone else having problems?
41 REPLIES 41
ewoksco
Uninstall mcaffee that worked for me
Open Intel Collaborative Performance Control (CPPC) and check CPU aggressiveness. Chances are you might find it at 100%. Reduce CPU aggressiveness to80% (80-20 rule). This shall improve overall experience like no connection lost when packet is lost. Found this solution here: http://www.troublefixers.org/laptops/fix-sony-vaio-pro-wifi-issues/367/
