My HDD failed recently and after installing a new HDD and installing Windows 7 I have been unable to use my FN key to toggle the touchpad, volume, etc. Specifically the touchpad as I use a wireless mouse. I have tried to install various drivers which I have downloaded not only from Sony Support but from various mirror sites to no avail, the drivers I believe I need are:
However I cannot get past the first driver as it says it is not the correct version for my model, nor after 3 days of searching have I found it.
System Information
Time of this report: 10/10/2015, 09:37:40
Machine name: ADMIN-PC
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.150722-0600)
Language: English (Regional Setting: English)
System Manufacturer: Sony Corporation
System Model: SVE1511K1EW
BIOS: InsydeH2O Version 03.71.51R0180E5
Processor: Intel(R) Core(TM) i3-2370M CPU @ 2.40GHz (4 CPUs), ~2.4GHz
Memory: 4096MB RAM
Available OS Memory: 3996MB RAM
Page File: 1925MB used, 6065MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics 3000
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_0116&SUBSYS_90AB104D&REV_09
Display Memory: 1696 MB
Dedicated Memory: 64 MB
Shared Memory: 1632 MB
Current Mode: 1366 x 768 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: unknown
Monitor Id: SEC3541
Native Mode: 1366 x 768(p) (59.998Hz)
Output Type: Internal
Driver Name: igdumd64.dll,igd10umd64.dll,igd10umd64.dll,igdumd32,igd10umd32,igd10umd32
Driver File Version: 8.15.0010.2618 (English)
Driver Version: 8.15.10.2618
DDI Version: 10.1
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 4/3/2012 03:19:44, 8034304 bytes
Any help would be much appreciated.
Hello Tuckmando,
There are a selection of drivers and utilities, including the touchpad driver, available on the Sony support site, the link below will hopefully take you straight to your Vaio models support site where you can download the files you need.
SVE1511K1E Software and Downloads
