Hello
I have a vgx-tp3z media centre and i have managed to break the wireless antenna that comes with it. Without it the wireless reception is awful. Does anyone have any ideas where i can get one, or as an alternative will any other external antenna fit the sony thread that the antenna attaches to?
Ive tried Ebay but no luck!
Thanks
Rob
Hi Rob,
This one comes up from time to time. The antenna has a LEFT HAND THREAD and you can try a commercial model to see it it will fit.
Unfortunately, previous posters have not found one that fits perfectly and it may be worth contacting the nearest Sony Service Partner to see if they can source one from Sony.
Have a look here: -
http://support.vaio.sony.eu/computing/vaio/contacts/asc.aspx?l=en_GB&m=VGX-TP3Z_B
Thanks Blencogo ill try the link
many thanjs for your time
Rob
