VPC-EB4X8E Extreme Overheating!
profile.country.es_ES.title
neeco1987
Hello.
I have serious overheating problems with my Sony Vaio VPC EB4X8E. The temperature of the CPU, GPU, MB, HDD it's always between 70ºC-95º, I bought CS-GO and I can't play it because the laptop it's shutting down itself because overheating. It's driving me crazy, most of the times with only a few tabs open in google chrome, the fan it's always runing at full speed, 90ºC, can't touch the back of the lap. On idle, no program open, 70ºC.
It is clean, fan is free of dust and everything...
Please, some advices!
Message was edited by: neeco1987
Tags (4)
1 REPLY 1
Thalamus.
Champion
Hi neeco1987,
welcome to Questions & Answers..
How long have you had your vaio.?
If your Vaio's fans are working, it may be worth buying some compressed air (you should be able to get this from your local PC shop), then holding the can upright give the vents a short blast from a distance of approx. 10cm if you hold the can to close you could damage the fan..
